What's that noise ..
bastenblood
Hi there , I hear this clicking noise since I bought my 2002 Envoy . It sound like something is loose.
The ticking accelerate as the rpm goes up , and past 3k rpm is barely noticeable .
I never had a major problem . I recently put a new manifold O² sensor , new battery and cleaned the tb.
Here's the video :
[video=youtube_share;dqVphxg88aM]http://youtu.be/dqVphxg88aM[/video]
I want to spot the problem before It get worse . Thanks in advance .
First of all you have a hard starting truck there. I takes mine about half the time to start. I would change your fuel filter, check your fuel pressure and fuel pressure regulator and throw in some fuel injector cleaner. You might have a leaking injector(s). Also check your plugs.
How many miles/kms? How long since your last oil change? Ever change plugs? Any other maintenance history we should know about?
146 000 KM ( about 90 000 mile) . Oil change every 5000 km . Terra-Clean Treatment for injectors in November .
Never change spark plugs (Since I got it at 135 000 km) , but got my six AC Delco on the way .
And I need to say when made the video this morning the temp was near freezing , It does'nt normally start like that ,
and the ticking noise is not as loud as the engine heats , but still noticeable .
Do you smell exhaust under the hood? My exhaust manifold gasket failed and made a similar ticking noise. As the engine heats up the gap closes and seals the manifold. You would also notice the noise more on the exhaust side of the engine.
Nope , no smell , also have a new Walker muffler and removed resonator , the exhaust system look fine ..
I'm going to change the fuel filter and the plugs this afternoon to be sure .
OK. Sounds good. Make sure to answer Roadie as well. He knows these trucks. Also I would highly recommend checking your fuel pressure. It will give you a heads up if any of the injectors are leaking down.
Six AC Delco plugs and new fuel filter installed and even add some Kleen-Valve in the oil , maybe it need
some time to work but the motor still sound like a diesel ..
[video=youtube_share;7XrWN-JsCpo]http://youtu.be/7XrWN-JsCpo[/video]
