FloGrown
- Joined
- Aug 22, 2014
- Posts
- 7
I'm having a issue that I cannot figure out for the life of me. When I first start my 05 trailblazer LS the vehicle shakes/vibrates (mainly when the ac is on but has done it with ac off a few times) but after a little while it will go away and not come back till the next day or few hours later (always smooth while moving) once I've stopped driving. I have also had a problem with the trailblazer randomly shutting off out of no where it only happens when I'm at a stop and the vehicle is not moving never had a issue while driving seems like idling has a hard time keeping proper RPMs but only at certain times and this is what's killing my nothing is solid everything is internment. So I have done these things to try and resolve this issue with no success I throughly cleaned the throttle body, installed new iridium denso plugs, new cam sensor, thoroughly cleaned the cam actuator, used sea foam (vacuum and fuel), and switched/changed the oil to mobil 1 advanced full synthetic. I haven't changed the crank sensor and I have been told I need to do that ? I am getting a check engine light codes are P0014 intermittent exhaust (B) cam sensor over advanced timing (just replaced 1 month ago light is back) should I do the crank sensor to get rid of this ? and also getting P0526 fan speed circuit. Don't think the fan code is causing the shake just need to replace the clutch correct me if I'm wrong here ?
PS it's a 2005 Chevy trailblazer LS 4.2L I6 2wd with 100,235 miles aside from this the truck drives perfect no misfires, smooth running when this issue isn't present and great vehicle just can't figure this out please please please any help would be greatly appreciated
