I6 stock alt maximum output
MAY03LT
Founding Member
Delmarva
Before I dropped my mechman alt back in today I decided to see what my factory alt could do. I don't have an "official" load tester like a vat45 so I just loaded the system with what I have. With the mechman alt I clamped it at 250-ishA so I knew I could spank this alt pretty good. They claim 150A peak amps and I guess they weren't lying. This test was done at 2krpm.
While we're on the topic, I did some other tests too.
  • engine running 2krpm
  • 6 beam lights on
  • blower on 5
  • fan clutch engaged
This averaged 67A. Pretty much every one I've clamped has been right around there, which only leaves 80-ishA available for accessories.
Any readings at idle?
I'd guess 70ish. It should be able to keep up with all stock stuff on with some reserve.
Reactions: Gerbil21
You know when I did this I felt like I forgot something. Max output at idle would have been nice to know.
spb_osu
