Hi all, it’s been awhile but life has been busy and my TB has been ok up to about a week ago when a bunch of things went but I’ll just focus on my HIGE problem.
I’m fixing my 4x4 disconnect and taking the half shaft out it was so brittle the next of the disconnect came off with the axel, no big deal I knew I could get it off, then the big problem hit.
I continued to take the disconnect of and from it being so brittle it broke off in the hole of the oil pan. I tried chiseling it out and no go, I tried prying it and nothing.
I was told I could run a metal pipe threw from where the other cv axel hole is and pound it out? Is that true? Will it cause damage?
I’m not dropping the pan I’ll go without 4 wheel drive before I do that. Also there is a black cylinder in the middle that is able to move, someone told me to use vice grips to pull that out before I pound out what’s stuck.
I just want to know if it’s a good idea for the pole or if there are other ideas that will 100% work cause I need my truck for Monday and right now the whole front end is ripped apart. Here is a pic of what it looks like now and as you can see I use the angle grinder to cut some of the metal of which worked but left some marks here and there. PLEASE HELP IM IN TROUBLE!!
