Had a few adventures last week. I ordered a 12" electric fan for the Envoy. somehow got it wedged in behind the grille and wired up to the old alarm switch in the dash below the radio. Now I can just hit the switch when I leave it idling and the extra air flow keeps the temp down. Ofcourse its in the 60's here now so have no idea if it will work when its 90+ degs next year.
Had the grille off and being lazy didnt bother to put it back on. Drove the Envoy all last weekend, the 1st extended driving in a long time. Probably put 75+ miles on it. Then watching the news last Sunday night and there was an Envoy IDENTICAL to mine except for the V-8 emblems that was involved in a hit and run about 4 miles from my house and the cops are on the lookout for it.....Here I am driving all over town with no front grille!!! I must have some kinda luck not to be in the slammer with a sprained neck and taser marks all over me!!
So I wake up Saturday determined to finally get that #8 spark plug changed. But 1st my work truck has had a CEL coming on and off since i went thru a concrete cloud when they were repaving a street a couple weeks ago. Throttle postion sensor so i figure it needs cleaning. Boy did it....I cleaned on that bad boy for a solid hour. Got it looking good and back together, fired it up and.....3000RPM idle!!!! Thought it would throw a rod.... Tried the cutting ignition on and off, etc but no help at all. Now Im in a panic as this is my daily driver for work. Drive it around a bit and no better, its stuck WFO....Its running down the road at 2200RPM without even touching the pedal. I should have done some more research but its close to noon now and Im desperate so I ck the local auto parts and the Irish have a re-man TB pretty cheap so I order it and its supposed to be in the store for pick up at 1pm.....2pm rolls around and havent heard a word, finally around 3 it gets there.
I pick it up and the change goes really easy.........UNTIL I remember watching a few videos where they recommend putting lock tite on the crews in the blade.... I better do that since its a re-man and probably doesnt have any. Find the perfect bit and somehow grab my drill to pop them out with. Put on the lock tite and not even thinking I put 1 on the drill and zip it back in......CRACK!!! Broke the screw off .........What a F'N idiot!!! Spent the next hour drilling the little screw out, somehow got a small square bit drove into the hole and was able to unscrew it through the back of the blade. Used a screw from the original throttle body and got it all back together finally... Fire it up and you guessed it.....3000RPM!!!!!!! Its damn near dark now so I come inside and do some research and ofcourse instantly Im reminded of the relearn it has to go through. Ive spent half a day changing a TB I didnt need to change....
Blew an entire Saturday for what should have been 2 hours work and o by the way..........Ol #8 is STILL in there!!
. F*ck it! It will need new brakes in the rear and also planning on swapping the diffs to the Saab's 3.73 next year so. And speaking of which, it was low on diff lube, took about a 1L. Weird since it's not leaking anywhere or I smoked a batch of bad crack when I filled it last
. Checked the other fluids and they were fine.
