Vibration, 07 9-7x 5.3 with AWD
Sid Coleman
Maryland
OK, now that I've got the new UCA reinstalled properly and Just Tires redid the alignment that came out perfect-thanks again all!, I'm back to why I had the UCA replaced. I'm getting a vibration above 70, but the odd thing is that it isn't all the time. And I can't tell if it's in just the wheel or feeling it in the seat as well. Had 2 different mechanics inspect the suspension for any bad bushings or parts-nothing now present that they could find. The original Michelin's that I bought it with were replaced by Goodyear Assurance Weatherready and were balanced when installed. Where should I start looking for the problem?
I am having the same problem with my XUV V8..
I have replaced the entire front suspension, and tires, brakes, rotors.. (all needed to be done anyways)
I am thinking it might be a U-Joint, but they all feel fine. Could also be a CV axle. But I hate throwing parts at it, not knowing for sure it will cure it.
Does yours start at about 72mph, and then go away around 80?
I had a similar vibration a while ago and It was a u-joint. Had both replaced and driveshaft balanced. Vibration gone. My rear view mirror would vibrate to where everything was blurry. Guy showed me the old u-joint had a spot where it would kind of stick when you would spin it. Not sure how you can test them without removing them. Had it done at a driveline shop. Cost somewhere north of 200$ for everything.
Mine starts around 70 and just seems to get worse the faster I go, only had it up to about 85.
I could have written that. Had the same issue, with one more complication.
The original driveshaft went to the driveshaft shop locally, the rear U-joint was completely wiped-out. However, the shaft was also bent. They claimed to get "most" of the bend corrected, and replaced both U-joints (although there wasn't anything wrong with the front joint.)
Before, noticeable vibration from ~68 mph, worst at 73 mph, gone by 80 mph.
After, dead-smooth at all speeds; even fixed a minor vibration I had starting at 25mph that I never noticed until it wasn't there any more. I had assumed it was rough road shake.
This lasted about two years. Vibration came back exactly like before--worst at 72--73 mph.
Both U-joints were still good. I grabbed a different driveshaft, replaced the rear U-joint in it, and fixed the vibration again. Same story--cured a lower-speed vibration I didn't know was there until it wasn't there any more. Apparently, the original driveshaft bend got worse again.
If this ever comes back, I'm going to have a Trailblazer EXT driveshaft shortened to fit my short-wheelbase Trailblazer--the EXT shaft is much larger in diameter.
Just made the connection-assume you are the same Schurkey from Team Chevelle! Thanks for the feedback, and nice to see you online again.
Yeah, that's me.
I have heard about--but never actually met--other "Schurkeys". We seem to be rare. Unusual. Odd.
I've been online, but not much activity on Chevelle Tech. I stop by now and then, more lurking than posting. One too many forum "upgrades" for me.
For that matter, I'm not on this forum much, either.
800DiagTech
