tranny oil
xj2202009
What tranny oil should I use for an 05 TB short wheel base with 130kmiles..autozone said this but I'm not sure
I was told by my CarQuest guy that only Dexron-VI was listed for my '05 TB.
I was not happy because Dex-6 is expensive,
but I'll do what I need to do to prevent a transmission repair/rebuild.
DEXRON-VI is the fluid specification for the platform. That bottle specifically says not to use with DEXRON-VI on its label. Return it and get get some DEXRON-VI or equivalent.
Reactions: 808_LS_EXT and triz
This is what I run in my transmission. $20 for a gallon isn't bad at all, and my transmission has 203k on it so it seems to be doing its job well.
http://www.autozone.com/motor-oil-and-transmission-fluid/transmission-fluid/valvoline-1-gal-high-mileage-dex-merc-automatic-transmission-fluid/819367_0_0/
I've used Super Tech Dex VI from Wally World as well. Haven't had any problems with it and it was $4 a qt.
Sensurround
