Now that is turned cold again I just found out my rear defroster is inop.
Is there an easy way to access the main liftgate electrical connector? I popped the rubber boot off the top but I didn't see it. Do you have to pull the headliner down or pop the plastic trim off the gate?
What I know so far.
Both tabs are attached.
The scanner is telling me the liftgate module is seeing the command to turn on.
Liftgate module is seeing 14v at the defroster relay
there is a rear grid circuit code (sometimes history, others current) when I delete it it does not come right back.
Not getting 12v when I touch the left and right tab with a MM
I am getting continuity to ground when I touch the left and right tab to ground.
What I know so far.
