Opinions on P1345
Robbabob
1,098
Hi again :smile:,
I have read a few of the posts regarding the P1345 code. Service station has replaced the VVT and a sensor or 2, and their final diagnosis while test driving with their scan tool is the timing chain has stretched to become 5 degrees out of sync. Along with their suggested parts to replace (water pump, serpentine belt, tension arm, and many gaskets) while the engine is apart, they want roughly $4,300. They say there aren't any engines available at their suppliers.
Between already replacing the starter, new battery and new brakes, I just can't see spending that much more on my '03 TB with the 4.2L, with roughly 184K miles.
It's not a DD and mostly sits in the driveway, errands to the store and recycle.
Options might be
A. List it and not hide the error code fact
B. Drive it until it implodes
C. ?
Opinions will be appreciated.
Thanks,
Robb
I think you might be better "served" by the forum if you list the sensors involved so the forum doesn't have to guess at the previous work.
Somewhat related is the maintenance schedule especially for things like oil changes along with how it is currently running. My "quick read" shows "AI first list" as a "stretched timing chain".... hmmm!
Parts replaced:
(1) DURALAST CAMSHAFT POSITION SENSOR & SYNCHRONIZER
(1) CLOYES ENGINE VARIABLE VALVE TIMING (VVT) SOLENOID
Low miles driven each year (less than 3,000), change the oil once a year. Oil is never "dirty."
Vehicle starts as usual, drives fine, seems like it is using more fuel than normal, cruise control won't engage.
If you are still in Florida, it is very likely that your SUV Body has not suffered from a catastrophic failure from Rust and Frame Cracking. Speaking from actual personal experience, I wound up getting a Long Block Engine (Heads Installed, etc,) with over 100 Factory Updates as a RE-MANUFACTURED and NOT a REBUILT Motor for my DIL's 2019 Jeep Grand Cherokee 3.6L Engine.
I lucked into finding "The Fraser Engine and Transmission Company" for selling my New Engine to me. They are AWESOME in the way of customer service, especially since I had to convince my Noble Auto Service Manager to exit his comfort zone from using another Engine Vendor exclusively... but in the end... they worked well together and all did a superb job with the Jeep having a properly running OEM REMAN Motor installed!
If nothing else, visiting the links and videos below will add to your Knowledge Base and to your need for doing a great deal of advanced Due Diligence so that this process can work out.
I know that this will NOT be "Cheap"... But like the rest of us, we know you well enough to swear that you LOVE that GMT360 and breathing New Life into that vehicle will be much less expensive in the long run than buying anything built after 2015. Fraser Engines probably have one BUILT and READY TO SHIP...Right NOW. It will not hurt to price out and seek availability HERE:
SInce the 1960's... Fraser has been a Very Big Operation while in the Business of resurrecting Engines and Transmissions and... Doing things RIGHT!
Hope this Data Helps!
Reactions: Robbabob
the code will disable cruise control. Hopefully, some others will chime in. However, my suggestion about "maintenance schedule" with "oil change event" wasn't all inclusive. There are other things like spark plugs and such. Not sure what happens with the coding, but potentially I would expect to see some misfires somewhere... maybe. Did the "garage" give you any kind of "health report" in terms of systems and things dealing with engine performance (ie. fuel trims, pressure tests, etc). Hopefully someone with experience with the code will chime in.... I am just providing ideas of things to check.... the repair dollar cost is making me choke... maybe you too. :-)
Reactions: Robbabob
Reactions: Robbabob
I would replace the crank sensor and then do a CASE relearn. They did do a CASE relearn didn't they? The first time I replaced the VVT cam gear, I had to take it to a dealer (before I got my own Tech 2).
I have not heard of the chain in these engines stretching to the point of needing to be replaced, definitely not at that mileage, not like its younger siblings (*cough* 3.6 *cough* Ecotec *cough*). I only replaced mine in my 02 because the chain tensioner failed and I replaced everything while I was there. It is a major job hence why the amount of money required. It's the labour costs more than anything.
How to replace I6 timing chain and tensioner
I explained in that thread that I had to do a CASE relearn after replacing the chain et al.
Jerameoba
