Low oil pressure & stall
mpd13078
Greetings all,
My TB stalled while gear was in park & low oil pressure light came on. Oil level is on dipstick is fine, regular oil changes, cleaned cam shaft position actuator solenoid not long ago. Check engine light is on, haven't pulled codes yet. Turned engine off, restarted fine.
Suggestions?
Thanks.
If your CEL is still on, start with getting the code read. Makes it easier to give suggestions when we have a direction to focus on. Did the low oil pressure light come on before, or after the stall? The few times mine's stalled out (either while driving, or had the steering wheel turned all the way to lock) I got the low oil pressure message after the engine cut off, which makes sense...
Reactions: Billder and Mounce
Hazy07
