like some more torque for my new tow vehicle
Sprung Monkey
406
Al
I’d like some more torque for my new tow vehicle
My new TV 04 chevy express 3500 6.0 4L80. has 360 ft.LBs however it weights
8K LBs it's actually a mini RV.
Towing close to 4K LBs includes trailer.
Please suggest upgrades for increased torque. To help towing. thanks
I think your only option there is to find out what gears you have in the rear end, and see if you can up them.. I bet it has the 3.08, maybe 3.42. Swap them over to 3.73, and then you should be good.
A cam swap and tune would be the way to go.
Richard Holdener on YT does A LOT of dyno testing of the LS engine. He did some tests of different cams on a 6.0L
And he also did some tests of the new Truck Norris cam although not on a 6.0L
@Reprise did do a swap on his and could advise a bit more on what to get. I know there is an advantage to swapping in a TBSS intake manifold however not sure if it increases torque or HP. Also depends on the clearance for a truck intake in your van.
ShitboxTrailblazer06
