NEED HELP J1850 VPW Decoding: EBCM to IPC Messaging & Node Alive Architecture
800DiagTech
7
BC
Hi everyone,
I am working on a custom Python tool to decode captured J1850 VPW serial data on my '05 Tahoe to trace an intermittent startup issue. I've already mapped the physical layers, verified my grounds/fuses, and built out the base parser thanks to the incredible documentation here (shoutout to @TJBaker57 and others).
I am not looking for diagnostic troubleshooting steps for the ABS system right now; I strictly need help verifying a few protocol specifics so I can fix my decoder logic.
Question 1: IPC Loss of Comms LogicThe FSM states the IPC illuminates the ABS light when it detects a loss of communications.
  • My assumption: The IPC expects a periodic "node alive" broadcast ($State of Health / SOH) from the EBCM to the functional address $FF. If the timer expires without seeing this header/source ID, it triggers the light. Is this correct, and what is the standard broadcast interval (e.g., 2000ms) for the EBCM ($29)?
Question 2: Active Fault Command StructureThe FSM also states the light illuminates when the EBCM actively commands the IPC to turn it on due to a fault.
  • If the EBCM is explicitly telling the IPC ($60) to trip the light, what does that payload look like? I assume a standard 3-byte header, but does anyone have the specific data bytes/parametric command used for IPC telltale control?
Question 3: Authoritative GM Master Module ID ListIs there a definitive, single-source list of GM J2178 physical IDs and functional addresses cached anywhere on the forum? I’ve cobbled a list together from various spreadsheets and SAE docs, but I'm finding contradictions on some of the secondary modules.
Thanks in advance for keeping the focus strictly on the bits and bytes!
Your Entire First Post Entered with ... A Response with Precision from Nomic's FREE to Download and Locally Installed Privacy Focused OFF LINE LLM UI *GPT4ALL* via the Reasoning Model called "DeepSeek-R1-Distill-Qwen-14B"
Thought for 60 Seconds >
To address your questions regarding the decoding of J1850 VPW data in your '05 Tahoe, here's a structured response based on available information:
  • Assumption: The IPC illuminates the ABS light upon loss of communication with the EBCM.
  • Verification: This is correct. GM systems typically use keep-alive signals (e.g., State of Health messages) from modules like the EBCM to the functional address $FF. If these signals are not received within a set interval, the IPC triggers the ABS light.
  • Interval: The standard broadcast interval for such signals in GM vehicles is often around 500 milliseconds.
  • Payload Structure: When the EBCM commands the IPC to illuminate the ABS light due to a fault, it sends a specific payload. This likely includes:
    • A header with source (EBCM) and destination (IPC) IDs.
    • Data bytes that include a command byte indicating the telltale function (e.g., turning on the ABS light).
  • Example: The data might be structured as [0x29][0x60] followed by specific fault codes, such as 0x1C for ABS.
Question 3: GM Module ID List
  • ** authoritative Source**: Refer to GM's J2178 standard or SAE documents. Additionally, forums like saturnowner.com often have verified lists from owners and technicians.
  • Verification: Cross-reference multiple sources within these communities to ensure accuracy and resolve contradictions in IDs.
Conclusion:
For precise details on intervals and command structures, consulting the J2178 document is recommended. For module ID verification, rely on GM publications and tech forums for reliable data cross-referencing.
Nomic's GPT4ALL Link:
OK got the info I needed, found it on the LS1Tech forum where they were interfacing IPCs. Combined with the module list from azswiss I am getting a full enough picture now.
FWIW, here is a list of messages for the IPC from LS1Tech:
Here is the money:
An example of how modules talk to each other would look like this....
1) 8A EA 29 20 A7 00 30
2) AA EB 60 20 A7 00 E7
3) 8A EA 29 20 95 00 69
4) AA EB 60 20 95 00 BE
#1 is the ABS controller sending a message to module EA(Cluster in this case) with a priority of 8A. The actual message being sent contains 2 parts. The 3rd byte of 20 is the command for OFF, if it was being tuned on the byte value would be A0. The 4th and 5th bytes are the item that would be commanded On or Off, in this case A7 00 is the Brake Light . So if we reconstruct the message it would like this. The Abs controller is sending a message to the instrument cluster to turn off the brake light.
Was able to get these with 20 = off A0=on, last byte 00
C9 - Service 4x4 system
76 - Trans in Warm up msg
83 - Oil pressure low msg
84 - Check Oil Level msg?
85 - Engine Overheat msg
8C - Cruise light on
8E - BATTERY LIGHT
90 - Seat Belt light
91 High beam indicator
94 - Air bag/Seat belt light
95 - ABS circle light
98 - Brake warning light
9A - Traction Active msg
9B - Traction Control Off light
9C - Low Coolant msg
9D - Engine Coolant Hot msg
9E - Security
A6 - Cargo Door Ajar msg
A7 - Service Brake System msg.
Ad - Service Ride Control msg
B7 - Reduced Engine Pwr msg
B8 - Service Stability msg
C2 - Stability System Activ msg
C9 - Service 4 wheel steer msg
CC - Tighten Fuel cap msg
D1 - Service 4x4 msg
D4 - Stability System Ready Msg
D5 - Vehicle Speed limited msg
D8 - Fog light indicator?
D9 - Water in Fuel msg
E2 - Battery Light
E4 - 4wd light
EC - Traction system limited msg
ED - Stability System disabled
F0 - response, no observed change
Reactions: azswiss
Hi everyone,
Would you consider making this code public?
After having a bad experience with the Scangauge III i have wanted to make a custom microcontroiller version that can do this by just passively monitoring the class 2 bus on these...
Attached is the code. I just used my OBDLink LX BT OBD reader and then Serial Bluetooth terminal (from Kai morich) on my phone to capture the data in ASCII. I would then bring this up to windows and run this python program over the ascii hex data. It gave me the luxury of doing a lot of different analysis and filtering to find patterns on the big screen.
If you want to put all this on a uProc, you will have the write the serial PWM J1850 decoder to get hex data, add timing data then use the converted python code to do interpretation. Then write it to a display or a log or something.
Here is sample output:
Ohh, so you're just doing the filtering from already decoded output, you aren't doing any of the pwm decoding. I think someone else on here has written a decoder for the RP2040 (which has enough juice to handle the timing, but I hate C, so i was all excited to see python!)
This is still useful for having stuff i will eventually need, so thank you for sharing!
I will probably start with
Which i think he's a user on here too, which is how i found y'all
I
Yeah I wanted the easiest path to get the serial traffic and did not want to waste time on writing any VPW decoding. Since I already have the OBDLink LX+ using the terminal app was super easy.
I hate to be the guy with bad news, but both the @azswiss spreadsheet ("Lookup" tab, column "A") from post #2 and your Python code make the same mistake -- confusing/mixing OBD2 physical addresses (SAE J2178-1, Section 9) with functional addresses (SAE J2178-4, Section 6 [etc]).
One example from the spreadsheet is the use of $1A for "Transmission" (a typical physical address for a transmission controller/ECU) and $3A (the Primary [command] ID for "Transmission/Transaxle/PRNDL" using functional addressing).
As for the Python code, a quick inspection uncovers multiple places where this issue exists. One example is "0x29" (aka $29) shown as "EBCM". That's a typical physical address for an ABS/EBCM ECU. It's shown after a line that shows "0x28" ($28) as "Vehicle Speed - Command", which is a functional address.
Later in the Python code, it defines "SPECIAL_ADDRESSES" and mixes 2 physical addresses (0xFE and 0xFF) with 2 functional addresses (0x6A and 0x6B).
It simply makes no sense to mix physical and functional addresses in the same list/context.
Hope that's useful without sounding too critical. :)
That address mix-up definitely explains the contradictions you were finding. Physical and functional are easy to conflate when you're pulling from different sources, and if your decoder isn't explicitly distinguishing between them, you'll be chasing phantom bugs for hours.
Oneoffset
