@2001ZR2 those are still some hight trim numbers.....I think the next course of action is to get a fuel pressure reading. One possible scenario is low fuel pressure with poor atomization and the PCM is adding a little bit of fuel to compensate.
Two things need to be checked before moving forward.
1) All intake manifold bolts need to be torqued to 89 INCH- pounds. All 10 of them.
2) Fuel pressure needs to be checked.
The intake is notorious for having loose bolts.
122 deg isn't uncommon on hot days, I wouldn't sweat it. There's a lot of heat under the hood.
I've never really monitored intake temp. I might have to clean my green filter although I did about 3 months ago or I could be pulling to much warm air from the engine bay some how
