exactly where I placed mine, but with zip ties...Blckshdw said:My Morimoto ballasts came with a metal mounting strap. Attached those to the ballast, drilled a hole in the plastic headlight assembly bracket, and mounted them with the included bolt and nut. With the headlight removed, you can see both ballasts for the driver's side.
My flog light ballasts are laying flat underneath those, and unsecured. There's enough stuff on top of them to keep them in place. They don't see any use anyway due to the quad retrofit.![]()
What would you say is the best long term solution? The kit or the capacitor mod?Blckshdw said:DRL killer or capacitor mod is a must. The PWM signal of the DRLs is not good for the health of HID ballasts or high powered LED drivers.
CDJuda said:What would you say is the best long term solution? The kit or the capacitor mod?
I figured I would just do the cap mod, where are you guys picking up the capacitors? Ace hardware or something???07teebeeLT said:theyre different. DRL killer, deletes your running lights all together while Cap mod just gives them 100% power. I did the cap mod, much easier and can always just shut the lights off manually if i want.
Great post! thank you! The Cap is installed as far as I know, is there any way to verify that it's actually working? I used one of the splicing clips and I know they don't always bite through, so I'm just wanting to make sure this thing is acutally doing it's job.kickass audio said:You got it right for the cap mod. I did that and it didn't work as expected. I still had some ripple and I got a bigger cap to the same result. Nobody else has had that problem like I did from what I can see so don't be alarmed by it and do like you posted. I myself don't like using wire taps and rather splice and solder my connections but there is no problem with a wire tap here for it being such low amperage.
For grounding, what I did was take one of the little nuts off that hold the BCM to the floor and secure one end of the cap to bolt on the floor. I measured the resistance and it was 0 ohms for that bolt so its a great ground. Now for your cap you need it to be polarized. This means that for the cap you chose, the leg that is shorter than the other is the negative side and needs to be connected to ground on the body of the truck. Another way to know which wire on the cap is negative is to look at the label and you will see a stripe with (-) on it, that shows you the side of the cap that is negative which corresponds to the leg on the cap.
In regards to how you did the cap mod and had one light with problems firing, I would try swapping the ballasts from one side to the other and see if it remains the passenger side that does not fire or if it transitions over to the driver side that does not fire. If it remains the passenger side then you may have a bad relay (if you use them) or you could have a bad wire between the ballast and the bulb. If it transitions then you more than likely have a bad ballast. I found too on my truck with one ballast I had that was bad was that in the cold when my trucks voltage would be up in the 15's when ice cold the one ballast would take a few fires before it would ignite the bulb. If i stopped the engine and turned the lights on they would fire just fine with the voltage being below the 15's. It was weird. Other than that it would work perfectly for me every time. I keep the ballast as a spare now. Some other food for thought, if your ballasts are floating around, make sure they are not laying on the bumper rail, frame, anywhere metal that is the grounding point of the truck. I also noticed one of my ballasts had something weird where if I set the ballast on the frame it would arc a tiny bit and make the light output go down a little bit. One day I accidentally had my finger between the ballast and the frame and got a nice shock from it. It was an easy fix, just tighten the screws on the ballast a little and secure it off the frame.
You can change the settings in your DIC, but on mine the parking lights flash only during the day when you hit the unlock button. During dusk/night time hours my parking lights will flash and headlights will come on. The capacitor should not affect whether the headlights turn off or on.CDJuda said:When I hit the unlock button during the day the headlights don't pop on, is that a sign that it isn't working???
Sorry still a little confusing to me...
would a multimeter work perhaps? because neromally you only get like 10 volts versus 12 right? so in theory using a mutlimeter could verify the cap is working?kickass audio said:The way to validate the cap mod would be to get a tech2 scan tool like may03 has which is not cheap. Another way to validate would be to get a fast o-scope and look for any oscillation in the voltage. If the waveform is nice and steady then you successfully performed the cap mod.
As far as unlocking your truck in the day, I do not believe the headlights will come on at all. I think it should only be your parking lamps. I cannot say as my lights are bypassed with the relay so that they only come on when I throw the switch all the way to the right. I do know that my reverse lights only illuminate on unlock when its dark enough out so it leads me to believe that only the illuminated entry is possible when its dark enough for the photo resistor on the dash to recognize darkness and make the lights kick on to help light your path.
) turn on the truck, and shift into drive while applying the brake and you stand in front of the truck. DRLs should come on. Then have them toggle the headlight switch to manually activate the low beams. You shouldn't see a change in brightness.I think it's working, the right headlight would only come on like 50 percent of the time when I turned the truck on before the CAP mod. So far it's turned on every time and I've turned the truck on like 5 times today.Blckshdw said:Poor man's testing method, is have someone (you trust!) turn on the truck, and shift into drive while applying the brake and you stand in front of the truck. DRLs should come on. Then have them toggle the headlight switch to manually activate the low beams. You shouldn't see a change in brightness.
Your low beams may or may not activate when unlocking the vehicle, depending on how your perimeter lighting preferences are setup within the cluster. As mentioned, with the DIC, you can change this. Question is, did your low beams come on before when you had stock bulbs? If they did, then they should do the same now with the capacitor mod installed correctly.
already upgraded all of the overhead lights to LED's. I would like to do the dash lights and stuff but I'm not sure if I would have the time or patience for it.kickass audio said:No a multimeter would not work for this as they respond too slow and you need something fast to recognize the change in waveform. Only way to see a waveform is with an o-scope. You could do like blackshadow suggested with putting your stock halogens back in for a moment and turn the truck to run with the engine off and parking brake engaged and switch it into drive and then have someone flip the light switch all the way. If you did the mod right there will be no change in brightness from the low beams, if you did it wrong you will notice that when just in gear the lights will be slightly dimmer than when you flip the switch to turn them on manually.
Some cheaper ballasts also will make a very loud humming noise if you did not do the cap mod right as it will still get that AC signal form to make it so the ballast wants to turn on and off very fast and it will burn them out if you leave it that way. Some others have reported of hearing fast clicking noises from their relays they use to turn on the HID's.
Your next mod honestly I would say is to upgrade your lights to all LED's. It brightened up my interior so much that its blinding at night when the inside lamps turn on. Only downside is with my bulbs if you press the map light it is so dim that its useless to see anything with but I never use them anyway so im good. Don't forget though that you need a load resistor for switching your turn signal bulbs to LED's or you will get hyperflash and you more than likely have CK style stop lamps in the back so you need to get CK bulbs for those.
