Encountered an odd situation that I am clueless about while working on my '05 Envoy 4.2 I6.
Followed outlined steps to clean throttle body (big thanks to all the posts on that topic and it was VERY dirty). I figured since I had it all apart that I would also change the plugs. The plugs in cylinders 1(closet to radiator) through 4 were well worn and dry. When I extracted the plugs for cylinders 5 and 6(closet to firewall) the plug threads and tips were heavily coated in fluid. The fluid appeared much like clean motor oil (thick, slippery, slightly yellowish). I have to believe the fluid coated the plug as it was removed from its socket as the threads and tip were fully and apparently freshly coated, and thus assume the fluid was stagnant in the plug bay. The socket wrench nor the nut portion of the old plugs seemed to be coated. It was quite difficult to visually inspect due to the location, but I did not notice anything different between the various plug bays.
My truck runs substantially better after re-assembly, but concerned I have another problem that should be investigated further. Any thoughts or assistance would be much appreciated.
