over the past few days I've noticed that my engine temps have been going quite high especially when sitting in traffic. Friday it was 86 degrees out or something like so, was running my A/C and sitting in some bad traffic. I checked my temp gauge and I only saw it slowly rising. It hit 1 tick past.. then 2.. then 3.. and almost 4. I got freaked out, not sure what can be going on. When cruising down the highway at 45 minimum usually like 70 or so then the gauge reads 1 tick below 210 which I dont think is normal. As soon as I slow down again when I hit more traffic the temps slowly rise. On my longer drive back home today I had experienced the same thing as before but this time it hit 3 ticks max. It was also a lot warmer today, about 91-93 degrees on highway. Whenever I stop or get stuck in traffic and come to a stop, I dont hear the fan clutch engaging like I used to (even in colder weather). Did not hear the fan clutch engage, maybe it did once or twice but it seemed very faint and not so quick like it should be. Instinct tells me that when you hit 2-3 ticks above 210 the fan clutch should be on 100%. I hear the clutch engage on startup and it's on at idle but turns off when I drive to not be heard again..
Replaced thermostat and water pump 3 months ago. Weird. I did not replace the coolant temp sensor though which I should have. Coolant was reused from the thermostat change
No SES or service lights on
I remember seeing a post on trailvoy that the needle should be on 210 at all times unless you do heavy towing and are going uphill and its hot out.That may have been an over exaggeration though
Is it possible fan clutch is dead? or temp sensor could be causing this? I might get a coolant flush if that would even help. Wouldnt a fan clutch throw a code if it wasnt engaging??
I will further test on upcoming Friday meaning run the car idle and see what happens and turn on/off AC to see if temps drop/
Would like a second opinion on this
Thanks
Thanks
to the real experience here...
