Downshifting
bastenblood
Very often , I pass from D , to 3rd gear , to 2nd just to slow down without using the brakes , and then return
to D . Is this a bad habit to have ?
eh, not so much as long as your not revving the nuts off it. I use 3rd all the time to hold back on hills (I live in the mountains). I don't go down to 2nd at stops or nething just if I am going slower than 3rd will engage.
Incidently when you are going down hill and select a downshift after a few seconds if the engine is above around 1200 or 1300 RPM the PCM will cut out the fuel injectors giving you more holdback and infinite gas mileage (wooo) ...
I go D, 3, 2 every once in a while because I like the sound of my engine winding down without the resonator. :yes:
I have heard, AND I HAVE NOT VERIFIED, that using the trans in that manner can damage the sun gear.
I don't do it, so I never bothered to verify; but, if your concerned there should be info on the net.
Most of the damage to a sun gear can be attributed to incorrect shimming... Or excessive shim wear... Or... abuse and old age. :thumbsup:
If rumors were yadda yadda, you know the rest.
Good you said that though so it can be discussed... :wootwoot:
Cautionary tale: I've done the D-3rd downshift for as long as I've owned my TB (4+ yrs). In the last 6 months or so I added the D-3rd-2nd habit as well.
Long story short: A few weeks ago I had all three torque converter-to-driveplate bolts loosen and back out. Fortunatelyish one of the bolts backed out far enough to start striking the back of the engine casting (making a god awful racket) to alert me before it let go completely.
Turns out that the clunking noise that developed at startup and the harder-than-normal shifts were the loose TC bolts slamming back and forth against flywheel holes. I can't definitively prove that the downshifting was the root cause but I do know I'm looking at replacing a flywheel in the near future.
Moral: If you're going to do it, do so carefully and you should be fine. In particular, avoid aggressive torque reversals...if it feels abusive, it probably is.
vargas53
