I have a 2003 trailblazer with th 4.2 I was driving it today and it stalled it started right away but ran terrible the ses light was flashing I hook ip a code reader it came up p0300 any ideas is there any way to check a coil thanks
Disconnect one coil at a time, plugging it back in until you find the coil that has no change on the idle... once you figure which coil is bad, swap that coil with a different cylinder and see if the problem follows the coil....03 trailblazer said:I have a 2003 trailblazer with th 4.2 I was driving it today and it stalled it started right away but ran terrible the ses light was flashing I hook ip a code reader it came up p0300 any ideas is there any way to check a coil thanks
yes... install a new spark plug as well...03 trailblazer said:I hook up the scanner again it came up p0302 I guess thats cylinder 2 right no 1 is closest to the radiator right
