In the process of doing the frame and trans/transfer case/differentials from a 2008 Trailblazer. Will be using 2004 Buick Rainier harnesses throughout the vehicle. The Bravada and Rainier both have the Smart Trak style AWD (have the motor on the side of the transfer case) but the TBSS transfer case does not. My question is, once this swap is done, can I go to the dealer and have them turn off that portion so I don't get an error message on the DIC?
Next question. Donor trans is a 2008 TBSS 4L70E. I pulled pinouts from the 2004 and the 2008 and it appears they are the same with the exception of the TBSS trans having the turbine speed sensor. No worries there since it will just do nothing. I have read that supposedly GM removed the 3-2 downshift solenoid around 2008 due to DBW and torque management. From what I can see, unless the wiring diagram I pulled is wrong, the 2008 TBSS still has this. Are there any issues known to run this trans using a 2004 PCM?
