FOR SALE 2005 GMC Envoy
Gerbil21
Selling my 05 GMC envoy With 151k, I'm selling since I bought a 03 Tahoe Z71:2thumbsup:
Located in Queens, ny .
Asking for $4000
this is the SLT model so it has
Heated, 6-way power adjustable driver and pass. Leather seats
Automatic hvac, with dual zone temp controls
Steering wheel controls
Rain sensitive wipers
Sunroof
Turn signal Mirrors
I also have done a few things to it:
Hid headlights & fog lights
Black rims, Grille, and rocker panel
color matched handles swapped for stock black textured handles
tinted windows
tint strip on windshield
remote start
Tail lights were modded for all 3 bulbs on each housing to be both brake and turn lights, lower 2 are park lights
led bulbs in brake lights, reverse lights, front park lights and front cornering lights
blacked out chrome shifter and shifter bezel
redone audio setup
2awg wire straight from battery to rear cubby (80A fused)
added in early year intake tube with filter life indicator
Added in early year cabin air filters and driver side footwell lighting
replaced tire carrier
Sound deadened inner and outer door panels, rear quarter panels and hatch door
detrimmed side mouldings and debagged envoy logo from rear
Work done on engine
replaced- PS Pump, alternator, idler, tensioner, belt, spark plugs, intake manifold gaskets, valve cover gaskets & ignition coil gaskets, thermostat, water pump, o2 sesnsors(up & downstream), catalytic converter, exhaust after muffler. recent oil change and Coolant Flush and filled with Dexron
work done on Trans:
SK4l60e shift kit installed, vette servo, torlon check balls, new manifold pressure sensor, Fluid flushed and filled with Dex 6
work done on suspension:
Front susp. parts: struts, upper and lower control arms, tie rod ends, sway bar links and bushings,upper and lower ball joints replaced.
Rear susp. parts: sway bar bushings and links, rear shocks swapped to 2011 tahoe shocks for a much more controlled ride, new springs
Work done on Brakes:
front brakes upgraded to larger ext rotors, wagner Thermoquiet pads on all 4 corners, black painted calipers and rotors, new brake lines all around, brake fluid flushed with new dot 3
Audio setup:
Sony hu powering:
jl audio 3.5" c2-350x in dash Band passed(12db) at 160hz and 950hz
Tectonic elements 3" bmr on dash high passed(12db) at 160hz
Jensen duba4100 powering
stock bose subs in front door low passed(12db) at 140hz
6.75" rockford prime coax in rear high passed(24db) at 160hz
rear sub: klispch dual 8" tuned to 25hz (not included)
Sound deadened doors and rear hatch
this setup produces beautifully clear and loud sound that is precise and accurate, any sub replacement is made easy with a rear 40A fused power line for the sub amp.
all in all it is a great suv, with alot of factory options and work ive done, the upgrades and mods sweeten the deal :yes:
and the truck is SOLD!!!
Now onto the next project!
Now you're gonna have to replace your avatar :biggrin:
addicted559
